Aussie musical instruments technology - the didgeridoo
The following is a snippet from the magazine "Nature" appearing in the most recent issue. If you want an email of the complete article with graphs email me privately:
Nature 436, 39 (7 July 2005) | doi: 10.1038/43639a
Acoustics: The vocal tract and the sound of a didgeridoo
Alex Tarnopolsky1, Neville Fletcher1,2, Lloyd Hollenberg3, Benjamin Lange1, John Smith1 and Joe Wolfe1
Acoustic measurements show how a player can extract a range of timbres from this primitive instrument.
The Australian didgeridoo (or yidaki in the Yolngu language of northern Australia) is a simple musical instrument that, at the lips of an experienced player, is capable of a spectacular variety of timbres — considerably greater than those that can be coaxed from orchestral instruments, for example. To understand this phenomenon, we simultaneously measured the sound produced by the didgeridoo and the acoustic impedance of the player's vocal tract. We find that the maxima in the envelope of the sound spectrum are associated with minima in the impedance of the vocal tract, as measured just inside the lips. This acoustic effect is similar to the production of vowel sounds made during human speech or singing1, although the mechanism is different, and leads to the surprising conclusion that experienced players are subconsciously using their glottis to accentuate the instrument's tonal variation.
The didgeridoo is traditionally made from a small tree trunk whose core has been eaten by termites. It usually plays only one note, with the player's lips vibrating at a frequency near a maximum in the instrument's acoustic impedance2, which is a measure of how difficult it is to produce air vibration at a given frequency. Its musical value comes from the great variety of timbres and rhythms produced by experienced players as they alter their tongue position and mouth geometry.
Characteristic bands of emphasized frequencies, or formants, occur in the output sound and are similar to the higher formants of spoken vowels3. The acoustic mechanism responsible for the strong formant production has hitherto not been well understood because of the complexity of the interactions between the vocal tract, the lips and the instrument. The acoustic properties of the tract are particularly difficult to measure during performance because of the very high sound levels inside the mouth.
In these experiments, a broadband acoustical current was injected into the player's mouth, just inside the lips, using a tube (diameter, 3.7 mm). A probe microphone next to it (diameter, 1.5 mm) measured the pressure. The acoustic impedance was calculated as described4, 5.
Figure 1 shows an example of the vocal-tract impedance. The spectrum of the radiated sound was measured immediately after the impedance measurement, with the player maintaining a constant sound but with no injected broadband current, to avoid this appearing as noise background in the sound spectrum. The sound output is reduced for frequencies at which the vocal-tract impedance is sufficiently large, and the acoustic flow through the lips is inhibited. For frequencies at which the vocal-tract impedance is small, flow into the instrument is greater and more sound is produced. Results were similar on other didgeridoos and with other players. (For details, see supplementary information.) A linear regression of the frequencies of formant maxima/minima against impedance minima/maxima has a slope of 0.93, with correlation coefficient of 0.98 (46 measurements from three players; results not shown).
