Autotek Mean Machine 4000 watt gate driver
I have a Mean Machine 4000 that has some defaced gate drivers on the driver board that I can’t ID. They are on the wide side at 5mm wide. Just curious if anyone out there would happen to know what these are.
Thanks,
David
Hi barber
i have the same amp, but i accidentally cut off the rectifiers.
i took them to the milling machine and managed to mill off a slight edge of the silicon just enough for me to get a solder tab and then soldered on some jumper legs from another to-247 part but ideally i would like to replace them. the map works fine now and rails build properly.
any idea where i could get some?
