For disposal: I have an Avondale Audio SE200 power amplifier which is surplus two requirement as I have now upgraded to the SE400's.
The transformer is an Audio Grade 540va from Tiger Toriods
The SE200 amp boards have been populated with exotic component variants (audiophile types) in appropriate locations.
The power supply is the latest offering from Avondale the NCM3 with 60,000uF capacitance per rail totaling 120,000uF in total for the amp, and incorporating Schottky rectification (MBR10200)
The power supply also has its own soft start onboard!!
The case is from Modushop 2U 400mm deep, the facial is unmarked new.
Audition welcome by arrangement (Hampshire UK)
£1500
Free hipping to UK only
£1500
