Bazooka el1500
Here is what I am getting on the outputs... There is a ripple coming from somewhere...it's on the output drivers and the all of the dips
Clamp the transistors down and measure the DC across each of the emitter resistors. Since the terminals won't be accessible, you'll have to measure from the resistor leg to the positive speaker terminal. Post the voltage for all 8 transistors. Re-check them to confirm that the voltage is holding.
Nothing gets hot unless I put a load on it of course the outputs heat up but one bank will heat much much faster then the other. Also with no Audi signal if I short the speaker outputs the same bank of transistors starts to heat up.
Also I still have the dc offset of appx 80ma.
I guess that I should have been more clear. The reason that they're heating up is because current is flowing through them and into the speaker due to the offset. As was previously stated, it's likely not worth chasing down on this amp. The 80mv won't cause the amp to be unreliable and won't cause any damage to any speakers.
