Behringer iNuke 6000DSP
On the iNuke 6000 that's often a problem of connectors. I've also seen problems with dc-offset, usually caused by the pre stage or problems with the protection itself.
Before diving deeper into it, I'd suggest to check the connectors, clean the fans and cooling channel.
