best sealed box calculator for Andriod
getting to grips with designing my own speakers I want to use a sealed box and have been inputting lots of different drivers into a website calculator however I've noticed a few different results than the manufacturer recommends. having tried a different websites calculator I'm getting wildly different results for the same drivers . is there a reliable app that anyone recommends for android or a particularly good calculator I could use through Google please .the two I've tried so far are the hifi audio design sealed box calculator and the aj design calculator
thanks in advance
Choose your preferred box Q (Qtc) and divide by the speaker Q (Qts). Multiply this by the speaker resonance frequency (Fs) and you get the closed box resonance frequency (Fc)
Now take Qtc, divide by Qts and square the result. Subtract 1. Divide the speaker compliance (Vas) by your result to get the box volume.
Reactions: JMFahey and GM
ah that's interesting so the first part of the equation tells you if the speaker will be suitable for a sealed box in the first place by telling you what resonat frequency you will be able to achieve with the driver your interested in then the second part tells you the size the box would need to be
In a way yes.
There is a test people often do. Take Fs and divide by Qes. If the result is around or below 50, you might find a sealed box is the intended use of the woofer. 100 or more might suggest a vented box or other types.
In a way yes.
thanks thats the ebp then isn't it ? the first equation you mentioned Is really useful because you can quickly find out if the fc is going to be low enough to make using that driver worthwhile
Reactions: AllenB
OK, this implies
(1) volume=infinite to achieve Fc=Fs
(2) volume=Vas to achieve Fc=Fs*sqrt2 i.e. half-octave higher than Fs
(in general) volume=Vas/N to achieve Fc=Fs*sqrt(N+1)
e.g. 1/3 volume for one octave higher; 1/7 volume for 1.5 octaves higher; 1/15 volume for two octaves higher.
There is an old rule of thumb that says.. If the box is smaller than Vas/3 then it is acoustic suspension. If it is larger then it is infinite baffle. For this reason, Fc=2*Fs (ie: Qtc=2*Qts) has been a popular choice and may help you choose a woofer to use.
Reactions: wchang
