Best TPA3116 2.1 Finished Amp?
Hi. trying to decide which YJ model to get:
Yuan Jing Audio - TPA3116D Class-D 2.1 Stereo Amplifier [50W x 2] + Sub-Woofer [100W] + Audio Tuning - USD $53.50
Yuan Jing Audio - TPA3116+AK4490 2.1 Bluetooth Digital Amplifier - USD $83.47
Yuan Jing Audio - TPA3116D Class-D 2.1 Stereo Amplifier [50W x 2] + Sub-Woofer [100W] + Audio Tuning + Bluetooth [Blue Version] - USD $58.20
I see the blue version has 2x more large purple caps than the ak4490 BT ext DAC version. Which is better regarding power/bass note wise?
Which has lower noise floor?
Which has longest life/best caps?
I personally won’t be using bluetooth, only rca input. friends might use bluetooth input.
Or do you have other make/model you would like to suggest? 🙂
Know of any 2.1 boards using tpa3255 being sold soon? I’ve not found one.
...tpa3255...amp is ready
my suggestion is that this amp has weak caps but if you have a very strong psu i might not be a problem if you do not think that you need more than 60 - 100W per channel.
and i do not need bluetooth....you too...so why not just a tpa3255 board...?
What is you overall budget for your amp?
DC30 48V TPA3255 + NE5532 + IS1864S Bluetooth 2,1 kanal 150 Watt * 2 + 300 Watt Klasse D audio Digital verstarker in DC30-48V TPA3255 + NE5532 + IS1864S Bluetooth 2,1 kanal 150 Watt * 2 + 300 Watt Klasse D audio Digital verstarker aus Verstarker auf AliExpress.com | Alibaba Group
budget is around £50 for tpa3116 2.1 amp. for tpa3250, up to £100 but prefer £50-£80. Willing to spend a bit more for 3e-audio quality. As i like what they make a lot. I also wanted a finished product. I’ve worked with a lot of amp boards. So something ready made would be nice change.
I am using dc-dc converters to power them. i can splash on another Sure 300w boost for a over killl but plenty of margin power supply or if i can find a half decent 150w-200W boost converter. Maybe i add a extra large cap on dc-dc convert output 🙂 ?
Don’t remember seeing that YJ 2.1 tpa3255 before. is it good? noisy? Some what over powered for 50w speakers
no idea...i prefer after the Fx502spro the tpa boards 😀
ok...its your decision:
here is the thread:
TPA3255EVM to complete amp (advise needed)
class D forum 2nd page...😉
