Bias el34 pp
Hi all!
Just finished a pp el34 in ul mode.
Have around 440v at plate. I have set
bias to 40mA per tube.
Will that give a plate dissipation of 17,6 W?
Do i think right?
What would you set for mA with 440 platevolt?
Regards//Daniel
35 mA per tube sounds better to me, at first glance. Seems like 70 mA per tube (140 total) would put you closer to class A than to AB1. You'll want to check datasheets and experience first, just my two cent guess here. No sense dissipating all that heat if you don't need to. The object is simply to reduce the crossover distortion. Once that's accomplised, additional bias just runs things hotter and consumes more power.
In addition to listening, have you compared THD with 35 mA and 55 mA ?
I have, and the difference is essential.
Does the amplifier work at class A or AB1, depends on the used power level.
With 55 mA the class A operation extends to higher power level, but finally AB1 is reached.
In an ideal world a valve would have a square-law curve at low currents and then linear at high currents. To get distortionless push-pull you would either bias at the centre of the square-law region or at the centre of the linear region - anywhere else would introduce distortion. Real valves are not that simple, but the general principle still applies: there are two good bias regions, one at quite low current and the other at quite high current. Sitting between them increases distortion, but perhaps not as much as it would for an ideal valve. My guess is that for an EL34 with a 440V HT 35mA is right in the middle so best avoided. Use either 10-20mA with fixed bias for AB (B except for the smallest signal)) or 50-60mA for AB (A except for the largest signals).
