BlackStar ID:100 TVP
I have a BlackStar ID:100 TVP. When switching the voice control or the TVP control the amp does not stay on the selected setting. If I set the voice to clean , cruch, gain, etc. the control led light with blink between settings. The same happens on the TVP control. At times it will also cut out and no sound will come out of the amp when it is seeking between settings.
So far I have done a visual inspection of the circuit boards. No visual damage. I have also blown out the pots with no results. The front circuit board contains all the controls and pots. attached to the back of this circuit board is a processor board.
Has anyone come across this issue and know what the repair is?
I tried getting a schematic from BlackStar but they won't give it up. Searching the net only turns up a few hits with others having the same problem and no fix.
I know this is five years or so after this post but I seem to have the exact same problem with my TVP:15. Both the voice and the TVP controls jump all over the place. I've tried a few puffs of CRC Cleaner, turning the amp on through the manual setting and doing a reset. Nothing works.
Did the original poster or anybody else have any luck fixing the problem? I had planned to sell this amp as I moved and am downsizing all of my gear. Now I can't sell it in this condition obviously. I may donate it to a group that gives away guitars to needy people.
