Hello!
I have old broken Brüel & Kjær 1023 sine generator and need maintenance manual or just schematic diagrams for it.
Can anybody help?
I have asked manual or schematics direct from Brüel & Kjær and their agents, but they state, that they dont have product support for those old equipments anymore.
Can anybody help?
Moi! Well your not alone, I've obtained one three days ago, and it seems to work, but a circuit diagram and a user manual wouldn't be totally wrong... If you search for "1023" at Brüel&Kjær website you can get some service and tech specs, so you know how to connect the unit, I've also the Distortion Measurement Cntrl Unit Type 1902, and likewise, no service manual... but there are some info of the net, that is of some use anyways! Terveisin, Routsista. Du kanske kan svenska rent av.... 😀
Manuals Plus - Test Equipment Manuals
ARTEK MEDIA (eBay ID: artekmedia)
Those are my preferred suppliers of manuals.
~Tom
~Tom
I have little info about BK1902 and 1023
http://web.telia.com/~u16130716/Pics/BK1902.pdf
http://web.telia.com/~u16130035/ampzilla/BK1023.pdf
If you need moore info try with SP in Sweden . (or a similar Calibration company i Finland.)
I have the service manual for the 1023. Bit busy at the moment but will see if I can send a copy in the near future.
Brüel & Kjær Type 1023 Service Manual
The Service Manual for the 1023 (or at least part of it) can be found at the Manual_Exchange yahoo group Manual_Exchange : Manual Exchange
The direct link to the B&K 1023 download page is: http://groups.yahoo.com/group/Manual_Exchange/files/Bruel & Kjaer 1023/
You may need to subscribe to the group for accessing the file section.
Does anyone have a PDF service manual for the B&K 1023 Sine Generator? I've got a damaged one that I'm trying to repair. Something on the PSU board is loading the -15 V rail with about 3 Amps.
Andrew
Andrew
I found my 1023 service manual and can do paper copies on request.
Have a look at C314 and C315 1u5F tantalum caps (one of these is hidden under a cable tree) on this board.
Maerz 2016 - Hallo as-audio,
ist es möglich, das B&K 1023 service manual auch als jpg oder PDF zu bekommen ? Wir haben hier im Museum einen Generator mit Fehler geschenkt bekommen und würden den gerne wieder aktivieren. Trafo und/oder Netzteil scheinen defekt zu sein. Mein Telefon steht im hifimuseum.de im Impressum. In unserem Museums-Flohmarkt sind jede Menge an tollen Geräten als Gegenleistung zu besichtigen. unter flohmarkt.ipw.net
Gert Redlich Wiesbaden
Hello Gert this is an English speaking forum. If you wish to post in another language, translate it to English as well.
Thank you.
Google translate:
March 2016 - Hello as audio,
it is possible to obtain the B & K 1023 service manual as jpg or PDF? We got here donated a generator with errors in the museum and would like to re-enable it. Transformer and / or power supply appear to be defective. My phone is in hifimuseum.de in Contacts. In our museum flea market a lot of great devices are visible in return. under flohmarkt.ipw.net
Thank you.
Google translate:
Hallo Gert,
Dies ist ein englischsprachiger Forum. Wenn Sie in einer anderen Sprache zu schreiben möchten, übersetzen sie auch auf Englisch.
Vielen Dank.
Hello Gert,
This is an English speaking forum. If you wish to post in another language, translate it to English as well.
Thank you.
Google translate:
Vielen Dank.
Hello Gert,
Thank you.
Google translate:
Post 11 / 12: as always it turned out to be a short Tantalum cap on one of the supply lines.
There are plenty of these so it is useful to inspect with an ohmmeter of high resolution.
diagram added
I can send Brüel & Kjaer type 1023 circuit description and schematic.
File size is 4 MB, but attachments are restricted to about 1 MB here.
Any way to circumwent this?
as audio -
can I get a copy of your B&K 1023 service manual?
I've been trying to access it on Manual Exchange with no luck so far.
tnx
Bob
tnx
Bob
The sm can be found here:
https://elektrotanya.com/bruel-kjaer_1023_10hz-20khz_sine_generator_sm.pdf/download.html
Yes, this is the one I send regularly, not sure who did the upload.
This is a photo scan however, may be useful if somebody does a
good scan of the service manual sometime.
- Design & Build
- Equipment & Tools
- Brüel & Kjær Type 1023 Sine Generator
