Hi
Does anyone has a schematic for this amp. I need to set the bias. At the bias set point, there is a switch which is selectable between EL34 and 6L6.
Please assist.
Please assist.
Is this the older type or the infinium?
The infinium is self biasing, assuming the correct valves are selected with the switch. All the switch does is add a 5k6 resistor to the bias chain.
Schematic here:
Schematics
I own the 333 non XL version, if you buy the Bugera matched tubes, they come with a letter printed on the octal base, justconnect a voltmeter to the RCA Cinch socket, set the switch to EL34 or 6L6GC, set the trimmer according to the table below
https://www.bax-shop.nl/downloads/d...eiding_vervangen_buizen_gitaarversterkers.pdf
Schematics
Thanks alot guys for your info and assistance. I do not know what version this amp is but it has a tube selector switch and a trim pot for bias.
I always, if the customer doesn't want to pay for graded Bugera valves, measure the current drawn on balanced output valves. Look for about 45% dissipation to run moderately cool.
- Live Sound
- Instruments and Amps
- Bugera 333XL schematic
