HI everyone,
I am trying to fix a Marantz SR-810 receiver. The receiver apart from other issues also has a blown diode which was so bad it was no longer possible to identify. Also not able to find a service manual for the SR-810. However I did find a service manual for an SR-1000 and it seems to be very similar build looking at pictures of the internals. The service manual suggests that the zener diode that is blown in my unit is a BZ-140 which google tells me is a 14V 1W zener diode.
What would be a suitable replacement as this diode is no longer manufactured?
From what I know about diodes, it will have to be 14V and at least 1W. Higher power rating is fine provided it fits physically. Any suggestions?
Cheers guys and ladies.
1N5351B - Zener Single Diode, 14 V, 5 W, DO-201AE
1N4743A - Zener Single Diode, 14 V, 1 W, DO-41
Thanks Rayma. Is it just the voltage and wattage that is important or did you make a recommendation based on other characteristics of the BZ-140? What else matters? Thanks again
Use the 1N4743. Remember that in most cases zeners are shunt regulators, not series. You have to drag more current through a 5W zener for it to regulate well. If you replace that 1W zener with a 5w you may see poorer regulation of the supply.
Yeah thanks for the advice guys. I will use the 1N4743. Yes something blew the diode AND the fuse...I am learning so will see if there is anything else I can find faulty that took them both out. Thanks again.
Just noticed, the 1N4743 is a 13v zener. The original seems to be a 14v. Won't that be an issue?
Uuse a 1N47xx or equivalent, I assumed the voltage was right when you presented the number. Use the right voltage. Find a 1 watt 14v zener of whatever number.
I guess if you can only find 1.5 watt it would have to do.
For the life of me I can not find a through hole 14v 1W zener diode 🙁
NTE144A
http://www.nteinc.com/specs/5000to5099/pdf/nte5061a.pdf
Thanks rayma but arrow has no stock, digikey don't know about it, mouser don't know about it, nothing on ebay. Exists on that pdf only 🙂
How's this, give them a call. Search Results Page
NTE Electronics NTE144A Zener Diode, DO41 Type Case, +/- 5% Tolerance, 1W, 14V (Pack of 2): Amazon.com: Industrial & Scientific
NTE 144A | NTE Electronics Semiconductors
- Design & Build
- Parts
- BZ-140 Zener Diode equivalent or suitable substitute
