Can Motor-Run Capacitors be used in a cross-over?
I am looking to repair my Beovox loudspeaker cross-over, and need 15uf (schema) or 16 uF (actual used in the speaker) . The existing caps are bi-polar.
Of course I find several MKP capacitors, 15 uF is easy to find.
but I also stumbled upon MKP motor run capacitors. They have a low equivalent resistance; they have a low loss factor; and they come in 16 uF.
In fact, they can handle quite a current. (Even though I don't need power at my listening level, under 80 dB).
My straightforward question is: can I used these in a cross-over? With their low resistance - at least in the woofer section.
(I use them in my tube amplifier, works great)
Yes. I also didn't hear the difference if the film cap was small. I do use them to get a value not available in the motor cap. Fine tuning, you know.
EDIT: I've read and been told that motor caps are "soft on top". That hasn't struck me audibly but I've been meaning to measure it for years. Still haven't gotten around to it.
Hi sser2, could you elaborate on that?
I don't have much experience. Now I don't use speaker level crossovers, but when I did, I noticed dull lifeless sound with some (not all) newer metallized polypropylene/vegetable oil capacitors in 2-5 uF range. The badness wasn't subtle, it was right in your face and apparent to lay people. Tweeters were BG Neo-3 and Neo-8. Never had problems with the older Dielectrol (dreaded PCB) or even older foil PIO.
