Can TL431 be used as a bias transistor??
I use a TL431 (with a capacitor to bypass it) as the bias voltage source in my MOSFET-output current-dumping amplifier.
Don't forget that the minimum voltage produced is 2.5V, so it may not be useful in a bipolar-output amp, and also that the voltage doesn't vary with temperature, so it might not be appropriate for use in many cases.
lumanauw said:
Nelson Pass use it in one of his Firstwatt amplifier
In Firstwatt F4.
TL431 is used as a precision VBE multiplier.
As F4 works in Class A the insensitiveness to temp. is not a problem.
In Class A temperarture compensation can be less of a problem.
Usually after warm up for some time, the bias will stay very constant.
