capacitors' effect on range
hi!
happy to be here. what a huge place hence sorry if this has been answered somewhere at some point.
so i'm revamping my gear a bit and came across a fairly simple question: do capacitors affect the frequency range's end?
let's say my cabinet's high frequency range starts dropping at 13khz and i would like to improve that. would replacing the capacitors of the crossover with better ones change that? or does it only depend on the tweeters? or maybe both?
thanks in advance for any insight 🙂
Short answer: no
What wiseoldtech said.
An old dry capacitor (we are talking electrolytics here) may definitely develop high ESR, which is equivalent to an internal series resistor, which will eventually attenuate the whole tweeter output, not just its "high end"
it is the capacitor value that sets the various xover points in a xover filter
i know but what i'm interested in is how far it goes after the last crossover point.
okay so if i don't see a general decrease i'm good.
thanks guys for the quick and clear replies 🙂
thanks again for confirming that. so for the example in my first post, i should replace the tweeters and not worry about the crossover or its parts.
btw. sorry for not hitting the "thanks" button but it seems new members can't use that at first.
You might do well to elaborate on your gear and measurements.
Seems odd you can measure the frequency response of your speakers which demands relatively elaborate equipment - measurement mics etc, yet cannot measure a capacitor for capacitance, esr etc which can be done with any £5 Ebay component tester.
Reactions: JMFahey
  • we don´t know your current tweeters
  • how do you know they drop above 13 kHz?
answer to both:
none of that matters because i just wanted to know about the general kind of impact capacitors have. the values i used in my first post were just examples.
thanks again for all replies. my question has been answered 🙂
