Hi all,
I wanted to get a discussion regarding Carvin's power amps and mostly because there is so little out there on what I consider an under discussed company that makes pretty fantastic power amps, all things considered. I'm also hoping to absorb some wisdom along the way 😉.
I've been using Carvin for the past 5+ years and I've haven't found a better amp considering: price, RMS output, THD, SNR, slew rate, dampening factor and weight. This turns on the "too good to be true" part of my brain and I wonder where the magic is happening at such a low price point.
For instance:
DCM3800L
DCM3800L Ultra Light Linear 3800W Power Amp ? Carvin Audio
SPECIFICATIONS
OUTPUT POWER
1 CHANNEL RMS continuous
- 8 ohms: 750 watts
- 4 ohms: 1225 watts
- 2 ohms: 1950 watts
BOTH CH RMS continuous
- 8 ohms: 700/700 watts
- 4 ohms: 1150/1150 watts
- 2 ohms: 1800/1800 watts
BRIDGED RMS continuous
- 8 ohms bridged: 2300 watts
- 4 ohms bridged: 3800 watts
Peak Power: 5000w (2 cycle pulse power)
- Frequency Response: +-.5 dB 20 Hz - 20 kHz
- THD< 0.03% @ 50% output, <.1% 20-20 kHz @ 90% output
- Output Topology: CLASS A/B
- Power Supply: Switchmode - 60% reserve - see kick drum test
- Damping Factor: >500
- Slew Rate: bridged mode >50v/µs
- Sensitivity (@ 8Ω): 1.4 Vrms
- Signal to Noise Ratio: Greater than 106 dB
- Input Impedance: >20K ohm balanced
- Speaker Guard™ DC production for drivers
- Soft-start power-ups: prevents AC breakers from tripping
- Over-Current: protected
- Under-Voltage: protected
- Thermal: protected
- Fan: variable speed
- Shock-proof SMT construction
- FR4 fire retardant circuit boards
- Aluminum chassis
- Air Flow - "rear to front" for cooler rack
- AC generator friendly
- AC Input: 120VAC 60HZ
- Fuse: 25 amps
- 2RU rackmount
- Dim: 19" (48cm) wide x 10.5" (26.6cm) deep x 3.5" (9cm) high
- Weight: 14 lbs (6.4kg)
- Made in the USA
- 3 year warranty
And the price tag...$669.00 (which is about $100 more than they cost 3 years ago) If this data is true then that means these amps spec better than other power amps easily 2x in price. They are rugged too. I used DCM3800L and PLX3602 side by side, same subwoofers and the PLX got almost alarmingly hot. The DCM3800L didn't break a sweat - slightly warm air venting from it after 10 hours of EDM music at program. I should also say that the majority of their use is outdoors in loose dirt (very dusty when people dance) powered by a portable generator.
Can anyone shed some light on the mystery that is Carvin? Does anyone else have experience with their amps? Is this just perceived quality or this this a diamond in the ruff?
Cheers.
For instance:
DCM3800L
SPECIFICATIONS
OUTPUT POWER
- 8 ohms: 750 watts
- Aluminum chassis
- Fuse: 25 amps
- 2RU rackmount
- Made in the USA
- 3 year warranty
Cheers.
DUG, can you elaborate on that statement? I understand the math but where did you get those figures?
You will probably get more responses in the Solid State or PA Systems forums.
The 2000VA is from the pix of the back of the 3800W amp.
