CD PRO2 repair....
Hello out there
I have a B&O Beosound 3000 from '02 with a defective cd. The mechanism is a VAM 1253. It had difficuilty in reading the CD. When it succeed in reading the CD, it will play a couple of minutes, and return with the error (read in service mode) 37 : Translated in the service manual "Selection error". I cant figure out what that mean!
When it try to read the CD, the Focus is moving nice back and forth.
The output from the driver gives a nice output.
But the spindle motor does not run.
I can by the way see a wierd triangular waveform at the output from the driver, with a frequency of ~176khz.
This frequency is the same as the maximum operating frequency for the driver (TDA7073A). Maybee something is oscillating?
I can hear some acoustic noise when i rotate the disc with a finger.
But i cant really measure this triangular waveform at the input of the driver.
Have you heard about these driver fail?
Thomas
