Looking for chassis that are similar to what's being sold here in the store. Mostly interested in 4U and 5U and compatible with F4, F5, F5T, F6, Aleph J...
I'm in Canada (Toronto) so preferably something that can be ordered from a Canadian vendor to avoid import duties and costly shipping.
Any clue where to look for these? Any help is greatly appreciated!
Thanks! Cheers!
Thanks! Cheers!
I'm not sure about Canada, but I can tell you from experience that modushop has high quality chassis! Modushop Chassis
But if you are on a tight budget, perhaps eBay or Amazon?
Cheers! 🙂
Cheers! 🙂
Yeah just contacted them regarding mounting holes on the heat sinks and some other details like shipping pricing as it looks much cheaper to begin with so maybe it's more feasible for people outside of US...
Another option may be to look at the chassis on aliexpress. Just an example of one on there for an amplifier: Aliexpress Aluminum chassis
It's not anything new. Shipping from China can be quite expensive, so you've got to pay attention.I just looked at this chassis better and it appears that the shipping is through the roof! Perhaps you should look at others on there and see what they are charging for shipping. Not sure if Trump tariffs have anything to do with it or not?
jeff
I'm not sure of the size chassis you are looking for, but this chassis has free shipping: Aluminum chassis
It adds additional $100 CAD for shipping to Canada but it's still lower than anything else without shipping. So probably around 30% save...I just looked at this chassis better and it appears that the shipping is through the roof! Perhaps you should look at others on there and see what they are charging for shipping. Not sure if Trump tariffs have anything to do with it or not?
The only thing I'm worried about with the one from AB is heat sink efficiency...
Something to fit in F4, 5, 5-T, 6, Aleph J so heat sinks are a must and probably 4U ones with dimensions similar to ones from Modushop.I'm not sure of the size chassis you are looking for, but this chassis has free shipping: Aluminum chassis
Or I'm completely misinformed and those kits can go in smaller ones?? 😐
A nice amplifier chassis with heatsinks is an UNENDING journey here over the last 40 years. Most suggest the Italians Modushop but there must be something local and cheaper? Maybe? Hopefully?
Maybe if you know a machinist that will work cheap in their off hours.
jeff
What amp are you using to put into a chassis? I used an icepower amp to mount on the bottom of the chassis I purchased from modushop. Icepower claims that you really don't need a massive heatsink. After I connected everything in the chassis, it did run quite coolish to lightly warm.
LOL ok that's good to know...A nice amplifier chassis with heatsinks is an UNENDING journey here over the last 40 years. Most suggest the Italians Modushop but there must be something local and cheaper? Maybe? Hopefully?
These are class D so that's why. I'm mostly looking to build class A FW and similar...What amp are you using to put into a chassis? I used an icepower amp to mount on the bottom of the chassis I purchased from modushop. Icepower claims that you really don't need a massive heatsink. After I connected everything in the chassis, it did run quite coolish to lightly warm.
- Design & Build
- Parts
- Chassis hunt
