Clarion DRX9255 not working
Hi I'm trying to resurrect an old Clarion DRX9255, it's stopped producing cd audio, it plays radio fine.
I tested the cd mechanism, it works and produces good clean audio, the problem is the signal disappears somewhere between the DAC, equalization circuit and pre-output.
I've seen many DRX9255's online with extensive re-capping, could this be the problem here? could old caps be causing the signal loss? They appear fine with no sign of leakage.
thanks in advance
