Class AB Biasing (article)
Thanks!
jacques antoine - Class A does not have an optimal bias for low distortion. It is a case of "more is better". 😉
jan.didden - The optimum bias does depend on signal level. I blasted auto-bias in another thread because I prefer inherently linear designs.
The biggest variable is temperature. My main takeaway from the analysis is that I may have picked an optimal bias for normal listening levels, but at high volumes, the bias will drift into the overbias region.
Ed
  • Thank You
Reactions: chermann
Thanks!
Ed
At high volumes most drivers will be complaining well beyond the delta between default and optimal bias. Looking at the curve for 0.22 ohm resistors hints at 0.087 A as a happy medium for levels between 1 V pk and 8 V pk, with distortion no greater than 0.025%. The distortion for 16 V pk and 32 V pk is about 0.05%, but I'd sure like to see the speaker showing less than 0.025% added distortion at those drive levels.
Lower distortion is good, of course, however beyond a certain point it's more an indication the amplifier is doing the Right Thing rather than an audible benefit.
Nonetheless the data is incredibly useful. I used to think more bias up to a quarter or half an amp on class-AB was better; apparently not.
Works well enough in sim but I need to finish a few projects yet before I have time to bench test that. I'll let you know then. Main concern shown by the sim is bias stability vs ambient temp.
Aside:
Since a rough and fast tonal tuning is feasible by means of Re, all tonal circumstances included, I would determine Re tonally.
The bias can be adjusted very precisely following.
The hearing is roughly distinguished: low bias: tonally brighter, more "resolving", with "markers" that let you locate sonic events better - high bias: more corporeal, less locatability of sonic events, more "saturated".
Reactions: analog_sa
