I am experimenting with some QE08-200h transmitter tubes which use a so-called Giant 5 Pin base. These are in excellent condition except for corroded contacts.
Now, I live somewhere which means without a lot of effort, and maybe not even then, I cannot go out and buy Deoxit D5 or whatever. If I try to import it with a air freight courier it may get snaffled up as corrosive, apart from costing the earth!
So I was thinking to boil the sockets with deionised water / white vinegar, then washing off with deionised water.
I'd be grateful for any wisdom from you all!
I would use a cotton bud with Brasso or Silvo finishing off with 3 in 1 cycle oil. Or purchase a tin of Switch Cleaner from 100006500 200ML - SERVISOL - VIDEO 40/2, 200ML SERVISOL | CPC
Free postage if ordered on line.
IMO/IME, you are going in the right direction with weak acid. Use lemon juice, not vinegar. Don't boil, just soak for several hours. After soaking, rinse well with demineralized water and follow with isopropyl alcohol.
Hi Guys, the sockets are internally too complex for me to see how I could get too far with abrasives, hence favouring a chemical approach. Lemon juice and vinegar are almost the same in acidity terms ; which better dissolves gunk will IMHO depend on subtle effects - I will try one then the other if I have no joy maybe boil it then?
There is any socket image??I am experimenting with some QE08-200h transmitter tubes which use a so-called Giant 5 Pin base. These are in excellent condition except for corroded contacts.
If it is ceramic I dont recommend boil, as it may alter the ceramic coesion, mainly in the pins area.
If the socket use this claw cramp system pictured below take caution, its a big crap:
Or this:
Currently away from home; will post images shortly. The Giant 5 Pin socket is well named and there is a giant clamp thingy involved.
I am originally a chemist by training so something I can say with a fair amount of authority is that as one of the posters has pointed out, ceramics + strong alkalis (drain cleaner etc) is a bad idea, in fact even mild detergents (which are alkaline) can etch ceramic.
Thinking about it the best strategy will be solvents to degrease, then mild acid to remove corrosion, then deionised water to remove that.
The biggest problem I have (and the reason I posted) is that most household products now don't list their ingredients or I'd be at this like a rat up a drainpipe. Also I live somewhere I really am restricted what I can buy.
What I really need is an ultrasonic bath! That's the lab method.
Be aware that the springs/clamps on them are likely made of steel ,I would not soak them in acid.
I would use pipe cleaners or interdental brushes in combination with the already mentioned brasso or silvo or dare I say it ;toothpaste.
Pipe cleaner - Wikipedia, the free encyclopedia
Toothbrush - Wikipedia, the free encyclopedia
Brasso - Wikipedia, the free encyclopedia
Hope this helps some.regards F.
years ago I salvaged great numbers of magnoval sockets from trashed TV sets. They were coated with a damn mixture of dust, nicotene, tar, and fat. I just put them into the dishwasher, and now they nearly look as new!
Best regards!
Best regards!
- Tubes / Valves
- Cleaning old tube sockets with common household products
