Compact 3-way monitor (horizontal orientation)
As you may know I am in the final stages of my first ever build (measuring and tuning). In the meantime, I am thinking through the concept for my next project and I am thinking a small 3-way monitor with horizontal orientation, i.e. this layout:
The conceptual requirements are:
  • self contained (i.e. electronics i.e. amps, crossovers built in) stereo pair
  • as compact as possible: dimensions as small as possible while still fitting the plate amp and drivers
  • very good LF extension (this is in conflict with the above)
  • SPL low to medium (no high SPL should help the above)
  • simple (to make) cabinet. Sealed box.
  • cost low to medium (i.e. low to mid tier drivers, MDF as main box material, cheaper electronics if available
Questions:
  • what are the options for plate amp and crossovers module? I am only familiar with Hypex FA series and from those it would be either the 123 or 253. They are both 360mm long, which would dictate the minimum size (width). I would like to find similarly featured options cheaper and smaller, if available
  • what would be a few driver options for each channel?
For example, if the overall width is 36cm, then a abt 20cm woofer can be (tightly) accommodated, together with a abt 12cm midrange and abt 5-6cm tweeter (typical tweeters with 10-13cm plate would not fit). Woofer chamber will need to be small, which would limit the range of suitable woofers, I suppose.
I like building smallish sized speakers, but I use them with a sub. Why do you want this all in one speaker? Where will you use it? On stands out from the walls, or sitting on a desk, or shelf? Is running speaker wires that much of an issue, or do you just want to be able to move the system around quickly?
I am partial to the Hypex plate amps, but there are other options which are less expensive... and which are smaller.
The amp board from @uriy-ch is a good option. Another good option is Zoudio AIO4CH, there is a thread on it if you search.
I am familiar with the Epique in Dayton Audio range and the 7in Epique version looks cheaper, has higher excursion but smaller diameter/area. Indeed, a similar solution, slightly larger. Smaller chamber on the Epique.
If 8in can fit, what about this one:
https://www.parts-express.com/Dayto...400W-RMS-DVC-Subwoofer-2-Ohm-Per-Coil-295-708
