connect a bluetooth transmitter to the output RCA-type speaker output jacks
Hello: how do I connect a bluetooth transmitter to the output RCA-type speaker output jacks of my home audio receiver? Notice the plural -- jacks. I see a lot of bluetooth transmitters with 1 set of rca jacks, that is 1 white for common, 1 red for hot. So do I need to buy 2 transmitters if I have 2 (rca-type) speaker out jacks on the a/v for 1 "set" for stereo? The a/v also has a toslink connection. Will that connect to a bluetooth transmitter (with toslink) for both (stereo) speakers? I will be getting bluetooth speakers to be totally wireless.Thank you.
I presume your home audio receiver has two pairs of R - L audio output sockets. (see image).
If so, one pair of these red and white RCA output sockets should be connected to the red and white RCA input sockets on the bluetooth transmitter.
If that information is not helpful, please post a photo of your receiver connections.
I am assuming that you are trying to setup something that will take a Bluetooth signal and play it on your existing stereo? This is common.
Or are you transmitting a Bluetooth signal from your stereo output to somewhere else? This is not as likely, but how you’d described it…
audiosr said he would be getting bluetooth speakers, so I presume he intends to broadcast from receiver to speakers.
Since he has not come back, I can only assume that my information was helpful - or perhaps not! 🙂
