I'm not really looking for the schematic but someone familiar with it or Crate amps in general.
My lead gain channel has an active bandpass filter and 2 band EQ.
I want to use a lower frequency in the midrange that the bandpass control will boost or cut.
I want it a good bit muddier and gutteral.
I'm assuming all I really need to do is change a cap, but I have no clue which one.
Does anyone know or have any ideas??
......maybe tell me which value it would likely be and what would be a good replacement to change it to a lower bandwidth frequency.
http://www.google.it/search?hl=it&q=crate+gx1200h+schematics&meta=
Not intended to offend you, but have you searched on Google?
And a suggestion: on most amps the preamp is the same. Try to find a smaller/larger brother of your amp and notice if the pre controls are the same. Might be a starting point..
