Creepage distances in PCB internal layers
I need to desigh planar transformer, but I can find no requirements for creepage distances in internal layers of the multilayer PCB. So far I think it is like that:
-if I can prove that multilayer PCB is voidfree, then I can assume solid insulation. Single layer of insulation must be 0.4mm thick for double insulation and 0.4mm FR4 woud break down at 16.5kV (1100V/mil breakdown voltage). I do not know FR4 specification for working (operational) voltage, only for breakdown voltage, so i have no clue what spacing to use between tracks of the same transformer winding.
-if I can not prove that multilayer PCB is voidfree, then I use creepage distance specified for coated PCB.
Can I prove that PCB is voidfree with 100% hipot testing and how high test voltage should be?
I would be grateful for some guidelines.
Best regards,
Jaka racman
working (operational voltage) for the whole winding would be 450V and 900V, hipot test is 4kV minimum.
I would be also interested in which standard is applicable. I am familiar with IEC(EN)60664, but I have not found anything about multilayer PCB.
Best regards,
Jaka Racman
Why don't you consider an ordinary magnetic device with wires instead of etched traces?
Hi.
I have been using planar transformers from Payton for almost ten years. Reasons are:
-repeatabillity
-relatively low leakage inductance
-low form factor
-low losses
-efficient cooling
It is much like difference between point to point wiring and PCB.
Problem with Payton is minimum quantity and tooling fee, since their range of standard products is small and they do custom designs.
Best regards,
Jaka Racman
