Hi All...
I do hope it's in the right thread I'm posting
The Crescendo with 4 output transistors VS Crescendo with 8 output transistors respectfully 140w VS 250w, how is the difference possible ?
Would som one help me figure out the calculation on the output on Crescendo 140W@8Ω and The 250W@8Ω
I struggle to see how it is calculated.
Both amps has a power supply at ±75Vdc how can there be a difference when the load is 8Ω.
I am well aware that the 250W has 8 output transistors compared with the 140W that has 4 output transistors
The biggest difference is the R31 1Ω parallel with Coil @ 2µH in the 140W version witch is not present in the 250W version.
Both amps has losses in the drain resistor @ 0.22Ω however the losses in the 250w version is almost not existent since the resistor is in parallel so 2x 4//0.22 in parallel compared to 2x 2//0.22Ω.
However this doesn't justifies the huge difference in the output.
In reality both amps are looking in to the same load, no matter if it is in AC orr DC perspective
So the big question is why is one amp rated to 140 W and the other 250 W and both are measured in 8Ω ?
Best Regards Allan
Best Regards Allan
