Cyrus / Mission 781 Refurb thread
Hey All and welcome to my speaker refurbishment thread!
First of all, I picked up a pair of Cyrus / Mission 781's for a steal intending to pair them with an old Pioneer A400 and a KI Sig CD63 CDP.....that was over a year ago!!!
So, this is for the living room, they are black, the missus does not like them...."there's already too much black in here...", "they are too big,..", (!?!?...good job I didn't end up with the 753's...), there are no grills....my youngest is 4......you see how this could become an issue..?
Anyhow, first of all, I started a thread here,..
Cyrus 781 x-over components
..because I found it quite difficult to find info on the x-over components, (I was intending to just re-cap and put into service..), but now, I need to refurb to the "missus standard" and thought I'd put it up here in the hope it will help someone else!
I will document with pictures as I go and any advice / recommendations are welcomed!
Episode 1 to follow....😛
Dismantling....
Both the woofer and the tweeter are held in place by four screws, the tweeter also having a foam insert behind, although "foam", after 30 years, is no longer foam, but dust!! Also, both drivers are soldered; no spade connectors here!
..and it's the same at the backplate, meaning I had to de-solder in order to remove the drivers / backplate.
The baffles are glued, (hot glue?), into place. Being 30+ years old, the baffles on both cabinets were not, "sound",and were pulled away from the cab quite easily, however, removing this glue is a knightmare!!!
Here are some pics...
Shared album - Dave B - Google Photos
...you can see the green foam that is still, or seems to be, ok, that surrounds the interior of the cab, the white "wadding" was rolled up into a "cylinder" and placed behind the woofer....
