I've recently bought a nice power amp Cyrus Audio Power. It sounds superbly, and I wish to connect it to my beloved PSX-R power supply.
Similarly of what I did with my Cyrus III, I suppose that some modifications will have to be done inside the power amp.
Someone has any idea about?
Thanks a lot in advance to everyone for your (always!) precious hints.
Ciao, Paolo
Ciao, Paolo
A fully regulated 300W DC power supply, the PSX-R uses intelligent connectivity which automatically adjusts its output parameters to suit the partnering Cyrus component.
Connection to a partnering Cyrus unit is made through a high quality XLR cable. In all instances this audiophile power supply can be added into the system without any changes to the existing components.
PSX-R – Cyrus Audio
PSX-R – Cyrus Audio
Yes, this is 100% true with any recent Cyrus Audio amp.
Unfortunately, the old generation of Cyrus amps and power amps was not ready to be connected to a PSX-R without modifications.
It has to be said that those interventions are quite simple to do, it's a matter of few coloured wires and a couple of jumper links to be repositioned internally.
The problem, is to know how...😕
Doesn't the user manual for the Power amp give instructions? It is only a manner of disconnecting the local PS to the amp board, there should be jumper wires.
They write that you need to install the connector "5" pins
https://www.cyrusaudio.com/wp-content/uploads/2017/11/Cyrus-Power_manual_English.pdf
YouTube
YouTube
Ok. Seems this amp is more complicated than the 3 and 3i i have experience with.
The PSXR uses a simple ttl logic circuit to determine whether an amp or something else is connected and adjusts the output voltage between 22v and 35v. It also monitors the power on/off button of the amp. At least that is how the old PSXR i reversed decades ago worked.
Bingo!!!
This is what I've found few minutes ago:
https://www.cyrusaudio.com/wp-content/uploads/2017/11/psxr_conversion.pdf
I hope this can be useful also for other people with the same problem
Thanks a lot to everyone answering me for the attention, you're always so kind.
See you next time, Paolo
- Cyrus Power modifications for PSX-R use
