DAC chips — Burr-Brown vs. ESS
After having tried several ES9038 DACs and still having one I can only say that it is not exactly progress. The various filters, features, nice abbreviations and stellar numbers are fantastic and all but I use equipment to listen to stereo music and that is not its strongpoint regardless of implementation. A few gifted engineers here claim their design to be superior (also more expensive) but even budget class DACs often seem to outclass the majority of ES9038 products. Oddly it is used both in ultra cheap stuff and in expensive stuff and they're nothing special in either. Just avoid.
With regards to Ifi Zen Air, FWIW I have had the Ifi Zen Stream and a supposedly superior Ifi switcher but the first was the worst product I ever owned and the second died earlier than chinese no name switchers do. A lot of high brow claimed superiority but not my best customer experience. By far/at all. I will not buy/try an Ifi product again.
The here often laughed at SMSL and Topping devices may have less issues, live longer and are way cheaper when selected right. Beware of the exceptions that also exist and their reluctance to solve design/software imperfections! I think when you live in the now a product based on ES9039 is worth a shot and AK4493SEQ is simply worth every penny. In a well designed device with correct AVCC, XO's, right output stage etc. and all that blah blah.
"How does a DSD1793 do DSD256?"
I found this answer:
"These settings are possible with the PCM1793 with the use of an external filter for the 384 kHz sampling, and the part is able to operate in DSD mode up to 2.8224 MHz sampling which is DSD64."
When you say better, exactly what you mean by this. All of them are D/A converters taking a digital input and converting it as accurately as possible to an analogue stimulus. If you can accurately hear a change in amplitude of say 1 uV yes there is probably a difference. What you hang on after the D/A is more problematic, amps speakers, etc. If the source was analogue, say a pick-up head then there is a difference by how it is designed and constructed, say a Koetsu Black or Dynavector Carat Ruby, or an SME arm compared to a LINN Itok arm it is in the mechanics. You may generalise and ask which is best an Atmel or a Microchip processor it is all just semantics, unless you know exactly what you want to do with it - listen to music or make some very intricate measurements and stare at the numbers. If I gave you two numbers say 3 and 7, which is the better number.
Ah Nico Ras reacting, that is always good and friendly.
Well better as in sounding good. Not a native speaker in English so catch me on the words and primitive expression if you like. Please listen to any truly fantastic measuring ES9038 device of choice and tell if you like it or not. Simple test. No need to argue. Just listen. Write down your findings and test another ES9038 device. Repeat. Evaluate. Introduce a few other devices based on other DAC ICs in the mix. Just listen and write down your findings. What is your conclusion?
There is something unpleasant in the high tones. Noticed not only by me thankfully. As said it apparently does not reflect in the stellar numbers but many that believe in that numbers blindly also notice the unpleasant highs.
