12DW7/ECC832 contains 1/2 12AXT and 1/2 12AU7.Do you know a dissimilar triode which contains 1/2 12AT7 and 1/2 12AU7 ??
Franco.-
Franco.-
Hi Franco,
No.
But then I wonder where would you use an ECC82 triode where you could not as well use the other ECC81 triode?
(As far as I know the tube you mention was specifically made for Dynaco. It got blastedly expensive locally, and I never liked the combination. I converted the usual circuit - input ECC83 and concertina splitter ECC82 - to a pentode input and phase splitter, e.g. ECF80, ECF82, 6U8 or such.)
No.
There is a good chance that no such tube exists. Here is the most complete list of dissimilar dual triodes that I have come across:
Duo Dissimilar Triodes
If you need dissimilar triodes the 12DW7 is versatile enough for most applications.
I am Editing my answer.
I am sorry, I did not see that it was for a 12AT7.
You are going to need to power a 12AT7 and a 12AX7. But if you have 6.3V, you can power 1/2 of the 12AT7, and 1.2 of the 12AU7.
Still only 300mA total filament current at 6.3V; or if you have 12.6V, then you can series up the 1/2 filaments of each tube, and only use 150mA.
My post below is before I noticed the original post was for a 12AT7.
JJ makes a very good ECC832 / 12DW7.
System I is pins 6, 7, 8. Plate, Grid, Cathode in that order.
System I is the 12AX7.
Filament pin 5 to pin 9.
System II is the 12AU7.
System II is pins 1, 2, 3. Plate, Grid, Cathode in that order.
Filament pin 4 to pin 9.
Pin 4 to pin 5 is 12.6V 150mA
Or connect pin 4 to pin 5, and connect 6.3V from that pair of pins, and the other end to pin 9 (6.3V at 300mA).
And Eurotubes.com in the US re-tests them extensively before shipping them to their customers.
https://www.eurotubes.com/store/pc/index_htm_files/ECC 832.pdf
Preamp Tube Descriptions
They are currently charging $15.50 (Sept 2020).
Do not modify your amplifier, get the right tube.
By any chance, is your amplifier the Dyna 17.5 Watt per channel amp?
Thanks both of you.
I can probably make due with a 6C4 and a 6AB4 if necessary. I am looking at the Iso-Linear schematic at Electra-Print which is for a stereo amp (each channel shares a 12AU7 & 12AT7) but I wanted to convert it to mono blocks.
Modwright uses a similar design in mono block form but altered the circuit so a single 12AT7 was used per channel.
Maybe it's not the best schematic for a SE EL34 amp, monoblock construction? I'm not impressed with the dual-input stage arrangement for an amp that could be so much simpler, or the global feedback for that matter.
- Tubes / Valves
- Dissimilar triode
