Distortion At High volume
I have a amp which is connected to a premap and fed via ipod. The amp runs fine with no noticable distortion when running at low volume. However the sound starts to distort when the volume is increased.
I know there must be hundred reasons for this to happen. But what is the most probable reason. Inadequate power supply? or improper biasing ?
Any Inputs?
As you say, many possible reasons.
You should look initially at where the volume control is located, and whether turning up the volume is causing overload of the following stages.
Biasing should not really change with volume, an inadequate PSU is a possibility.
This kind of problem takes seconds to pin down with a scope.
So your problem could be anywhere in the chain from preamp to power amp. The only way to know for sure is to look and see with an oscilloscope.
You could also try without the preamp and feed the iPod direct into the power amp.
Sure. Here is the schematic
322560d1357724892-philips-40-25-15-watts-amplifier-universal-preamplifier-circuit-pwrschemedit-jpg
