Diy 15 inch box with the box 15LB100-8W
Hello i want to build a diy 15 inch pa speaker now idk if the box 15LB100-8W is good for this i have a specications for speaker and i never design a box now i guess that i have to get a winisp and put in that spec and box idk and also i was tinking of using it as a subwoofer for some time is that like going to be a problem?
The 15LB100-8W is a good value speaker, but not much displacement for a "subwoofer".
The lower power 15LB075-UW4 worked well in the SS15 tapped horn, nearly the output of a pair used in bass reflex cabinets.
