At long last, I present the DIY Biamp 6-24 Crossover.
Attached is the "owners manual" which contains everything I have to say.
Basically it is a complete stereo biamp crossover which has 6, 12, 18 and
24 dB/octave slopes and filter poles independently adjustable over a
6:1 frequency range.
Quantities of the "Essentials Kit" are ready to ship to the store, and
should be available shortly. It includes the pc board and the selected
Jfets + bias resistors. The part list is complete and everything can be
obtained from Digikey and Mouser. I expect a "completion" kit to also
be offered.
6L6 has been provided with an advance copy to enable one of his
popular build guides, and Mike Rothacher has put together a simulator
for customization.
![wizard :wiz: :wiz:](https://files.diyaudio.com/forums/images/smilies/wizard.gif)
be offered.
for customization.
![snail :snail: :snail:](https://files.diyaudio.com/forums/images/smilies/snail.gif)
Thanks Nelson, this will be a perfect complement to a B4 or miniDSP! Once I dial in the slopes and frequencies on the B4 I can build an affordable dedicated x-over. This should also be great compliment to the LXmini to add a sub or two.
Hi Jason, will there be pre-order for the first batch of these boards/kits? If so put me down for 4 channels![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks again,
Olen
Thanks again,
Olen
Can this be used to tri-amp...
You would need 2 units
... or quad-amp?
now 3
dave
Assume we double up for Balanced operation?
Guessing similar to LXmini Analog Crossover, 2 are needed for Balanced Operations?
- DIY biamp 6-24 crossover
