Zeppelin Wireless Speaker Box
Hi guys. Bobby here from South Africa and I am wanting to do a project of copying the B&W Zeppelin Wireless Speaker Box. The design won't be exactly the same.
The outer casing I will shape from foam for mould purposes and then make the casing out of fibreglass.
It’s just I want to see if it can be done sort of project (I know crazy, right) and taking into account I know nothing about sound, etc so I am looking for how to spec it and purchase off the shelf items and amp boards through amazon/aliexpress. I do understand that the zeppelin’s internals are all custom made for that product.
Obviously I don’t want re-mortgage my house and have to sell my children to make this product.
Zeppelin Specs:
Bluetooth® v4.1, Class 2
Digital Signal Processing (DSP)
Digital amplifier
Drive units:
2x 25mm (1.0 in) double dome tweeter
2x 90mm (3.5 in) midrange
1x 150mm (6.0 in) subwoofer
Frequency response:
44Hz to 28kHz
Amplifier power output:
2x 25W (tweeter)
2x 25W (midrange)
1x 50W (subwoofer)
Input voltage
100V – 240V – 50/60Hz
Power consumption:
Sleep (network standby) Below 1.50 Watts
Standby Below 0.30 Watts
Inputs Network (RJ45 Ethernet or Wi-Fi)
Auxiliary – analogue (3.5mm mini jack)
USB – service only
Dimensions:
Height 188mm (7.4 in)
Width 660mm (26 in)
Depth 183mm (7.2 in)
Weight:
6.5kg
Bluetooth Codecs:
aptX Standard latency
AAC
SBC
My Specs:
Drive units:
Frequency response:
44Hz to 28kHz
2x 25W (tweeter)
2x 25W (midrange)
1x 50W (subwoofer)
Amplifiers: Would need some ideas here (doesn’t have to be individual amps as per the B&W model.)
Connectivity. 3.5mm mini-jack and bluetooth.
Power Supply:
Rechargeable Li-Ion Battery charging through a micro-usb port (located at the back)
Any other ideas you guys can think would be greatly appreciated. Please bear in mind, that I am less than a novice.
Any help would be appreciated. If you need to email me my addy is bobby@collectivedigital.co.za
Kindest regards
Bob
Zeppelin Specs:
Digital amplifier
Drive units:
Frequency response:
44Hz to 28kHz
2x 25W (tweeter)
2x 25W (midrange)
1x 50W (subwoofer)
Input voltage
Power consumption:
USB – service only
Dimensions:
Width 660mm (26 in)
Weight:
6.5kg
Bluetooth Codecs:
AAC
SBC
My Specs:
Drive units:
Frequency response:
44Hz to 28kHz
2x 25W (tweeter)
2x 25W (midrange)
1x 50W (subwoofer)
Power Supply:
Kindest regards
Bob
