DIY RCA "Y" splitter cables
Hello,
My goal is to biamp my speakers. And my preamp has only one "main out".
  1. Can I simply splice (soldering) 1 RCA cable into 2?
  2. Would this cause any damage to the preamp or to the 2 amplifiers?
  3. Besides testing for continuity, how should I test to ensure the output is equal to the 2 legs?
THanks.
Yes you can use a splitter cable. Your power amplifiers need the
same gain or one needs a volume control. To biamp 2-ways
you really only need a much smaller treble amplifier, and
adding a first order high pass to it by reducing the input
coupling capacitor will prevent bass causing clipping.
TBH bi-amping with similar amplifiers for me only makes
sense for 3-ways, one for bass, one for mid and treble.
rgds, sreten.
Why a problem ? ML's are not typical 2 ways, at all.
Some will feed the bass amplifier from an attenuator off
the valve amplifiers output (with variable level) to get
less change of character between the two amplifiers.
rgds, sreten.
