diy turntable - motor questions
Hi guys, I would really like to build me a turntable just for curiosity and have some fun building stuff that sounds. 🙂
My main problem now is the motor. I want something cheap, easy and effective, nothing exotic or superdupermegapower-torque.
What do you think about the motor of a microwave like this one: LINK
Is it possible to control it in order to have exactly 45rpm?
I've read about the altmann project and also the floppy from audioorigami, but both have big limitations. The first is pretty unhandy and the second I suppose doesn't have enough torque.
What do you suggest?
A microwave motor simply has to turn the turntable. Wow,
Flutter, Noise and Speed Stability are simply not an issue.
FWIW they seem to be synchronous motors (good)
with a gearbox on top (bad). It may well be possible
to remove the gearing and attach a pulley. FWIW you
can't control them, speed is fixed to AC frequency.
You'll need the right size pulley for the belt drive.
rgds, sreten.
Exactly!
rgds, sreten.
So maybe it could be a possible cheap motor. I don't care so much about controlling it, because most LPs are 45rpm, so I would just need one pulley. Right?
Do you have any other suggestions? Other cheap motors?
Most 12" LP's are 33 1/3 rpm, most 7" singles are 45 rpm.
TBH you'd be much better off cleaning up and trying to
improve an old turntable, or at least cannibalise one
for the major parts of DIY project.
I get the feeling ambition is way ahead of real knowledge,
and trust me, building a decent record deck is not trivial.
rgds, sreten.
Acvtre:
Your best ( cheapest ) bet is looking into a VPI motor ( Hurst 300rpm ). If you are serious about making something good you will need to have access to or own a metal lathe to make some parts. You can also look on ebay under turntable platters or parts and go from there. It can be very rewarding and frustrating at the same time !!!! Needless to say you have lots of research and reading to do. Just my opinion.
rgds, sreten.
this/\. look in your thrift stores or ask around especially the old folks. you never know what might turn up and often for free.
don't dismay the cheep plastic decks as they can be cannibalised and put in a better plinth. the old belt drive technics plastic stuff actually has a decent motor in them and can be had for very little money.
Thank you so much for your interest, but consider that I live in Europe and it's better to avoid the custom taxes if possible.
However, I'm still searching for a cheap (less than 20€) motor and I really don't know where to look.
It's not that simple, a synchronous motor will lock to the frequency so a 220V motor will run at different speeds for 50hz and 60hz. You will spend more on the PSU than buying say a Rega motor.
The easiest way is to use a motor from an old turntable.
