My wife has stolen the kitchen table back so I can't make any new boxes.
I need to make myself a new work table.
[ the kitchen table was a bit small anyway]
Before I outlay cash for materials I'm asking what the smallest size table people find useful for making full size boxes is and secondly is there a preference for a ply work top or boards, a sheet of hardwood marine ply is $150- and DAR hardwood in larger sizes for the rails is almost unobtainable just at the moment so I'd need to use pine for those.
Luckily I have 4 large bits of 120*120 spotted gum I can use for the legs
Depending on where you live, the second hand market is hard to beat for workbenches/old school desks/used office or industrial furniture, even if you need to modify them a little. I prefer several tables to one large one. You’ll usually work on one speaker at a time so each table does not need to be particularly big, although not sure what you mean by full size.
I went back and forth on this a few times. I made a nice 8’ deep bench for to build stuff on but was so sturdy I use it in the garage for heavier projects.
Now I use 3 5’ ikea desk/table tops that easily can break down and they’re cheap enough I don’t mind drilling holes for light and magnifying stands.
Each table seems to have their own function with reasonable space: soldering, computer and assembly.
Initially I used the Ikea tables as a way to figure out what I wanted and was worried if they were sturdy enough with the plan to build another sturdy desk but they seem fine.
For the sturdy table I used two grizzly legs with a stringer and glued three sheets of 3/4” plywood together, edged it with 1x4s and varnished all sides to help prevent warping. It’s been a good bench too.
https://www.grizzly.com/products/shop-fox-adjustable-height-workbench-leg-28/d2659
Never thought about using something as light weight as IKEA tables, which model? My wife uses them as sewing tables with the white tubular legs
The linnmon top with the adils legs, probably the same as your wife’s table.
Maybe borrow hers for a trial run since she stoled the kitchen table. 😈
There might be larger tops, but I ended up wrapping two sides of the formal dinning room. With those tables and two kallax shelves for storage.
+1 for IKEA. I have two of their Bekant standing desks. They're quite affordable, especially if you don't need the adjustable legs. You can also buy the tabletop by itself ($50). It's veneered particle board, so not fancy. But it's a nicer finish than plywood.Now I use 3 5’ ikea desk/table tops that easily can break down and they’re cheap enough I don’t mind drilling holes for light and magnifying stands.
Tom
I may have just found a workable solution in a sawhorse adaptor from local maker Rhino
Neat as I do need a couple of extra saw horse for work around the house
https://www.bunnings.com.au/rhino-trade-saw-horse_p5820759
https://www.bunnings.com.au/rhino-100kg-saw-horse-work-platform-attachments_p5820810
I already use one pair of the saw horses and I can afford the second set if I don't buy all at once. The WLL can be increased to by using F17 hardwood or LVL and not the cheap pine that is supplied
- Design & Build
- Equipment & Tools
- DIY work bench/table
