Driver Terminals
2.8mm, 4.8mm, 6.3mm spade connectors would cover all I have used over the years. The latter is used on some drivers. Since the driver terminals can vary in thickness, a bit of adjustment can be required to open or close the connectors a tad. You want a snug but not tight fit.
