I have been rebuilding a Dynaco ST35 amp. I am thinking of doing a new power supply External larger transformer and DC heater circuit. Has anyone tried this?
The little amp before in its original state run very hot. I have seen some threads that say the one thing about this amp is the power supply was never sufficient and is taxed.
Scott.
Scott.
Instead of that I would go dual mono. You can get transformers and chassis here.
Some items happen to be out of stock right now.
Dynaco replacement parts & vacuum tube audio amplifier kits from Dynakit
None of the original transformers are deficient, they run a bit hot but that’s to be expected in a vintage tube amp. My two st-35s have been working fine for the past 50+ years, I’ve had them for about 10, that seems pretty reliable 😉
Dave Gillespie makes a power supply board that allows for more capacitance and independent biasing for each channel; it seems to work well and sounds good to my ears plus it’s fairly quiet. I didn’t compare to the original power supply because the st-35s were not working when I bought them (bad caps).
Daves Store: Dynaco SCA-35 ST-35 EFB Upgrades and Restoration
Olen
Olen
