Earthquake 21" Subwoofer by Toids DIY Audio using SB Audience Rosso 21SW800
I’m new to the hobby, can some explain me how to choose between pro woofer and high Xmax woofer?
I want to build a subwoofer soon, and I’ve been suggested both.
After seeing this video, I can see the pro woofer can go as low than high excursion drivers. And in general, they are louder from 50 upward.
Also, the linked privided by maxolini amaze me! It’s amazing what people can come up with! 🤯
Reactions: maxolini
Any alternative for SB Audience Rosso 21SW800 for sealed cabinet subwoofer?
Do you have the cabinet already? How many liters of volume, depending on that you need to find a driver that fits your cabinet volume, normally the manufacturer recommends a given enclosure volume for a given driver.
Most of the time the car audio brands do it like that, PA or HT are more tricky. As you need to come up with the calculations by yourself.
If I were to buy a large PA subwoofer. I would go for the SB Audience BIANCO-18SW450.
It's a 18" woofer that can be had for 166 euro. So if you buy 2 of them. Then they are cheaper than the 21" and have more surface area.
2 of the 18"s simulate a little better than the 21" in a slightly larger case.
Reactions: GM
Interesting woofer - where is it avaliable for 166 Euro?
