eds Leakseeker comments
It's an old idea and has been around a while. Another option is described at Toneohm 950 multi-layer shorts locator
I vaguely remember playing with a Toneohm unit many years ago and they work OK. It is mainly going to sit in the corner of the work bench and be useful only occasionally.
After a while the whistling gets annoying, it was a bit like a theremin.
Another way of finding shorts is to use a 4 wire measurement technique by using a settable current limited power supply connected across the short circuit of interest and using a mV meter to find out where the voltage is lowest.
