equivalent for 2n3904
Wow, asleep for 12 years, and now gets a post.
Look at the specs again:
NTE123AP - Vceo 40v, Vcbo60v
MPS6531 - Vceo 40v, Vcbo 60v
I dislike using NTE for anything but emergencies, but in this case they have the same basic spec. Usually the real part is a lot less expensive than the NTE, and if I don't have the real part, chances are something else I have is just as good a substitute as the NTE.
In your specific application, are these the limiter transistors near the outputs? Those are not very critical, and are easy to sub.
You may find this company cross reference useful in the future:
http://bmamps.com/Schematics/Peavey/Peavey_Semi_Cross_Ref.pdf
thanx enzo
will have to ck out the reference later...
is prolly a limiter... because there was a bad resistor and possibly bad big diode(s) & bad output xistor on the power transistor section board
if I can see the numbers on some other boards I scavenged, I may be able to find a better quality than the NTE, go figure.. cheesy, Chinese garbage, I rekon?
I didn't know so this is good info u gave me...
ttys
My objection to NTE is not that the individual parts are bad, but rather the parts cost 3-10 times more than the real parts, and they are only approximately similar to the original parts. Why spend $1.50 for a transistor that is close, when the real transistor is readily available for 60 cents and is exactly what the circuit wants. By themselves, transistors can vary, but especially in applications like output transistors, current sharing is important, and then we want all the parallel parts to be the same. One NTE in a row of Motorolas is asking for it to either hog current or sit there like a lump and do nothing.
The MPS6531 on the Peavey 400BH board is just a limiter, it drags the base of the driver down if the output current goes too high. very common circuit. The 2N2222 is a heftier part, but there really is no current to speak of, so that becomes moot. Most any small NPN will work there.
I explained my objections to NTE in post #11.
Heftier parts like the 2222 will work. But there is something to be said for using low Cob parts in the current limit circuits. Smaller die = lower current and smaller capacitance. Part of the reason VI limiters are blamed for degrading the sound (compared to not having them) is their nonlinear parasitic capacitances. Always there, causing distortion, even when not in use. Really might not matter much in a Peavey product, but with higher end equipment you may need to watch things like this more closely.
