I am using diyinhk es9038pro DAC board.
PCM I2S connection taked from datasheet.
Then use DSD signal: sound is mono.
I am trying to find solution to change input signal routing using i2c from amanero.
Maybe someone has experience with programming i2c outputs of amanero and can explain me how to write register values correctly in amanero?
