etching tank
"Two conduits Ø 2.5 cm relatively simple.
Two miniature drills for tiles.
Heater. 50W
The holes along the tube a distance about 1 cm with a diameter of 1.5 mm"
No mention of "conduit" RPM. Drill motor running on variable DC supply.
Since "propeller" at bottom end of "conduit" works as pump to pressurize
fluid for spraying, it probably spins fairly fast (no clue here).
Google translate is your friend.
I build this
tested with green food colorant , but not tested with etchant
tub is a 20 liters pail
motor 60 hertz, 2 poles, 3450 RPM
pump-sprinkler is a 1 1/2 inch sewer pipe, actual outside diameter is 4,8 mm
pump blades made of lexan
pump throat is 10 mm
sprinkler have 27 holes, 3,1 mm diameter
All this for etching a pcb ? With ferric chloride possibly it's good to spray the etchant. Horrible method in any case. Stains everything !
I etch my boards in a plastic tray containing a Hydrogen peroxide solution ( somewhere between 10 and 20% ) and dilute Hydrochloric acid sold for cleaning tiles / toilets etc. Must be 10 % or 20%. Ratio is 2 parts hydrogen peroxide ( solution as you buy it ) to 1 part acid ( as you buy it ).
The boards etch in less than 5 minutes with a little rocking if the boards face upward. It's amazingly fast. Need a fresh mix each time.
Actually you just need to add more peroxide. No need to remake the mixture every time. Which also prevents having to figure out how to dispose the environmentally toxic copper solution every time you etch.
This is the commercial version of that machine..Jet 34 d
Nice build.... what you might consider is a lower support bearing for the spray tube, to prevent wobbling. We had a Jet at work for close to 20 years. Worked flawlessly until the very last years. What actually killed it was a replacement of the mercury lid switches, which was not sufficiently tight, causing etchan to leak into the electrical compartment which was on the side of the old machine. We used it with Sodium peroxide as etchant, which is another possibillity. Wether you need a machine for home etching depends on how much you neeed it, I guess, or that you quite simply just want one...😀
A mechanically simpler solution (as in no moving parts in the tank itself) is to make a bubble tank, with some needle pricked plastic tubing in the bottom of the tank, driven by an aquarium pump.
When you go to your pet supply shop remember to also pick an aquarium heater.
Killer combination for fast even etching.
Made a first real world test today
Simply preheat etchant by putting the gallon in a pail and keep the pail full of hot tap water, change hot water a few times.
used Mg chemicals stuff and had great results, works better than expected...
What he says.
I made this out of perspex and pipe glue. The thing is as solid as a rock, we call it the 'fish tank'. It gets a lot of use and works great.
attachment.php
The next image shows how I heat it and agitate. The black tube is a 'bubble curtain' designed for creating lots of tiny bubbles in a fish tank, this is powered by a small aquarium pump. The heat is provided by 4 glass encased power resistors. These are then encapsulated in wide diameter heatshrink tubing. HS tubing is extremely inert stuff. The heater is about 60 watts total.
attachment.php
I had reservations about the resistors getting too hot inside the tubing, but in reality they don't at all. The heater is powered by an old laptop SMPS. I do have to preheat the solution in a water bath with hot water before etching, otherwise the heater would take hours to get it up to temperature.
The PCB support was made out of some packaging that came with an IC I bought a few years back, and lifted up on little perspex legs. The heater and bubble curtain weave and sit between/beneath the legs. You do have to place a cover over the top when it's working otherwise it spits etchant over the top. I usually use newspaper for this.
Certainly far cheaper than buying something specialised. I keep the etchant in a non reactive plastic bottle when it's not in use.
