Expandable braided sleeving sizes?
From the Amazon link:
Size: Dia.1/4":25ft & Dia.1/2":25ft | Color: Black. Diameter expands by 50%. Our wire sleeve is made from PET
So if the diameter expands by 50% the 1/4" would become 3/8". Easy-peasy.
Warning: expanding the sleeving makes it shorter, so cutting it relaxed then stretching it will end up not covering the length you want. Stretch first then cut. Also use a lighter or candle to sear the ends or else the thing will unravel. Happy braiding!
You get spiral wrap, and old style waxed cotton thread as well.
And why don't you try cable ties, if you want to tidy up the wires?
Dressing up implies that the wires are visible?
You can also get a larger size heat shrink sleeve, and heat only the ends, so that it fits, that would work too.
