F/S Accuphase E-305 Integrated
The Accuphase E-305 was manufactured from 1987-1991. I have owned this amp for about 2 years, Years before the E-305 I owned an E-303. In between I owned several other amps, tube, SE tube, PP tube, several vintage Sansui solid state amps, vintage Marantz, Luxman and DIY solid state amps I built following threads on DIYAudio. To my ears nothing gives the balanced and detailed presentation like the Accuphase amplifiers.
The amp is nearly 30 years old So when I first received it I replaced all the electrolytic capacitors on all boards. The capacitors were replaced with the same values except in a few cases the voltage rating has been increased.
The E-305 has a phono section, 2 speaker outputs and tone controls.
The amplifier power transformer has a multi-voltage primary that can be wired for 100v, 117v, 220v, 240v. It is currently wire for 117v.
$1950 shipped
