Fan noise in speaker
Hello. I'm building a SPRO-2 based amplifier and I'm using three 12V/0,2A DC fans for cooling, but whenever I turn these on I can hear it a bit in the speaker. I'm using a 30W supply for the Pre amp for SPRO-2, and other circuits and I noticed that if I turn on the fans far from the boards(outside the final enclosure) and can't hear any interference. Does someone know if this problem is common, or if I could be solved with a better quality fan or a circuit?
Thanks in advance
