Feedback/noise when sharing power source with amp
I have completed a 19.6v speaker build. Audio quality is great. It has a voltmeter with a built in USB charger.
If I use a bluetooth receiver with independent power connected to the amp audio is great. As soon as I try and power the bluetooth receiver from the same battery that powers the amp, I get very loud static/noise.
I know one answer is separate power supplies, but this is not practical. Is there another was I can prevent this interference when sharing power?
If I use a phone or tablet and power that from the speaker there is no interference. Only when I use a bluetooth adapter (I've tried a couple). I have a pre-amp coming and assume that will also have the same issues when sharing the power supply with the amp.
How is it you get 5V (or whatever the BT receiver uses) from 19.6?
My Zoudio class D amp has that same input voltage and an integrated BT receiver. I dont know how the small signal power voltages are derived, but I believe there's 3.3 and 5V within that board - and these come from the main power input - somehow.
A "pre-amp" could easily connect directly to the 19.6V supply, not requiring typical single cell lithium consumer product voltages like a BT module is most probably designed to use. Maybe this discrepancy has something to do with it and the "pre-amp" board wont exhibit the problem.
I am using an external 5v Bluetooth adapter. The voltmeter is designed to run on 12-24v and is used to replace a cigarette lighter in a vehicle. So it downrates the voltage to 5v usb. When connected to any other 5v charger there is no issue.
I have also ordered a Bluetooth adapter that will run on 19.8v.
