Fidelizer PC Optimiser For Audio Applications
From their website:
Fidelizer will instantly turn your Windows Vista/7 computer to audiophile workstation for sophisticated audiophile player like J River, XXHighEnd, HQPlayer, foobar, etc. It involves no permanent modifications so system will remain safe and sound after restart so even system with normal Windows installation can experience better sound quality when needed. Backgrounds behind the optimizations is far advanced for someone daring to make free software so grab it while it lasts.
Fidelizer | Windows X's Live
The author of this is likely someone who does app development for Wxx and knows about before/after Registry changes. Tweaks for audio, W7, W8 are also on this site.
Using a tiny program like regshot.exe one can see the state of the Registry before and after and compare and get a list of changes.
Fidelizer makes up to 600 entries in Extremist mode.
Reviewing the sound aspect, it works as advertised. Sound improves, less hash on cymbals and upper ranges, cleaner all around.
However be warned, it you are not a power Wxx user this may not be for you.
Fidelizer will make Registry entry changes, then sit in the background and upon restart undo those changes.
In theory.
In practice you have a good chance of removing some functionality, on a permanent basis even after restart. I lost networking, the internet and browsers would not start.
Make a System Restore Point before installing this app, and if you really wish to dig around, make snapshots of your Registry to see what is being changed.
If you have experience digging around in your Registry then this app is for you, if you don't then I can only recommend it for a stand alone music server that has NO OTHER uses because there is the chance to 'brick' your OS.
Those risks being stated, it does exactly what it says. It strips your Windows OS down to an audio server OS, with audible improvement in the sound quality and makes a PC into an excellent front end for top end music servers and music players.
Ed.: This is a similar approach that cPlayer takes. It also unhooks most unused services, processes and functions. Sound improves, but you may lock up your system and need to restart.
Fidelizer is a wonderful free jitter reduzer for Windows
Hi, it wonders me why nobody speaks about it 😉
this little tool is a real winner! It brought my system a hugh steps forward in terms of better jitter performance!
I can't measure jitter but I think I can relyable hear it as meanwhile I worked intensly 8 years with the DIYparadise Monica DAC to get the best of a
Windows PC + USB DAC. (Which was hard work after all, from the start a PC source is behind a good CDP)
Fidelizer offers much better transparency and timing. The subjective feeling of background noise in music gets immediatly lower. My favorite is the Extermist modus! 😎
This sensitive setting is a quiete notecible step from the default "audiophile" setting where a normal work (Email, Internet) can still be done in parallel. In extermist set up the network is blocked.
So fellow: If your using windows (WXP, 7 or whatever) and you think you've got it all 😱 then use this additional tool in your PC and be prepared for a large improvement :cheers:
Of course some small numbers of other very good tools or players exist already but I think this Fidelizer in Extremist mode is quiete consequent as it shuts down huge areas of disturbing processes in Windows. Secondly harmonisates them to reduce Jitter effects when playing via USB DACs.
And the best it's easy and for free! and after a new reboot your system is back to normal again and can be used again for all other purposes.
BTW: My Linux Ubuntu has no chance😉 OK I never optimised it much. But many dudes said that you can gain so much from optimisations as Linux is anyway far better and ideal to computer music. But again its not as quiete, detailed and musical involving as windows + fidelizer (I use Sonata music server as player)
Was it a stock linux distro you tested or a minimalist one running jackd? Without customization you wont get great sound.
--G0bble
I'm not an expert but I concluded jitter is quite hard to distinguish even with the best 'theoretical' Hi Fi.
from what I've read, the most important part, is the stage right before the DAC chip itself, usually a buffer where the data is re-compiled before getting injected into DAC. Everything before, like usb transport type / usb cables / pc spec will not affect final 'quality', unless the DAC chip is bad to start with, like many laptops with bad grounding.
Lets be honest, unless you have your setup exactly like the producers, you will never hear as they heard it, not to mention everyones hearing is different, Why bother . :smash: it's like squinting your eyes at alow res picture in order to find more detail and damn, does doing that damage your sanity..
I believe CDP will always beat PC because there is more 'Synergy' with reading / processing / playing.
Actually, the CDP operates very similarly to the PC chain.
The CDP reads disc data into a buffer at rate corresponding to the disc rotational speed. Reading the data from the buffer is clocked by precise clock. The player maintains the buffer optimally filled by controlling the rotation speed - standard feedback control loop in the analog world.
The PC provides data into RAM at CPU speed. Reading data from the RAM into the DAC of the soundcard is clocked by precise clock of the soundcard. The chain maintains the RAM buffer optimally filled by the card waking up the writing thread via IRQs, telling the CPU to provide new data well on time - standard feedback control loop in the digital world.
--G0bble
For the same reason that windows needs customization and special software like jriver or fidelizer. One needs to minimize the number of processes competing for cpu cycles and the bus.
Simple isnt it? ;-)
G0bble
Sent from my GT-N7000 using Tapatalk
What is your experience in tweaking linux for audio?
There is no need for "tweaking", just configure the correct way as phofman already has explained to you (apparently without success unfortunately).
As for experience: I work professionally with Linux since 1995 for several companies and have a RedHat certified engineer (RHCE). Hope that´s good enough for you.
BTW I have worked on a project for TV streaming to mobile phones (serveral thousend clients) a year ago, and no we did not need to "tweak" the way you think it is required.
Being cynical is cool but clearly you either havent gone the mile or your attempts ended in failure for whatever reason.
G0bble
I´m not cynical, it´s you who is offensive. But well, that´s the kind
of situation the ignore list is made for.
I think we are both talking past each other. Crosstalk is best dealt with by disconnecting... 🙂
My apologies if I sounded offensive. I only meant to ask if your tried tweaking linux with the passion of an audiophile upgrader, not your general work experience.
... tried tweaking linux with the passion of an audiophile upgrader ...
If you want to "tweak" in the sense of improving something you
have to understand how it works first. It seems you haven´t even
bothered with reading what jack actually does and what it was made for.
They do have a well made website:
JACK | connecting a world of audio
Read it, understand it (or at least try) and recognize that you won´t
need it unless you are a musician.
Do we have any evidence that that makes any difference? A modern CPU uses less than 5% when playing music.
Only if one relies on faith 🙂
Evidence across the Internet? Sorry no.
The proof is in the listening... if you can listen to my setup at my place and swap it for your desktop maybe... depends on the rest of your chain... if it is transparent and revealing it should be replicable and repeatable at your place too...
G0bble
Now you are trying to be the armchair theorist. I have read all that you point to many times over. Like you are skeptical about my claims, I am asking you to be skeptical of the commonly held belief. We can keep posting like a ping pong match and all we will have is lost time spent at the keyboard. Then hopefully one day you will actually attempt it really well and test it on a system that you know reveals minute differences and discover what I claimed to be true. Until then we can let it rest. I stand by my claim and my purpose of posting is to inform and find out how many can repeat the experiment and agree or disagree. But having 10 people disagree on the Internet is not going to remove my personal sense of triumph or eureka moment at having successfully upgraded my source.
Cheers
The internet allows posting of pictures of graphs, or controlled double-blind ABX listening logs, or references to peer-reviewed scientific publications.
I think that would qualify as "anecdotal" or "hearsay".
Unfortunately old wives' tales spread just as easily over the internet as verified facts...
And I am asking you to be sceptical about the absolute accuracy and reliability of your senses. In the following picture, is one line longer than the other in A and B, and is one of the spaces between the wedges shorter than the other in C?
There is simply no mechanism that would change the data if your CPU is 70% idle instead of 90%. Or do you loose money when you make a bank transaction and the database server is not idling at 90% or more ?
Or is the content of Gobbles posts degraded because of the server load and in reality he did write something sensible ?
