I have SpeakerCraft amplifier. Model BB2125 which I believe is 125W/channel. The case has lots of scratches so this is good for garage or basement system. You can also repaint it and use it for DIY project. I am finishing third album thru this amp and everything is fine at normal listening levels. I have small mp3 player connected to it and when I push it to the max, the amp will cut out. No protection light. Just no sound for a split second. Not sure if this is due to the source or the amp itself. Unfortunately, I do not have a suitable preamp to fully test the amp.
The case with heatsinks is good for a DIY project once repainted. Inside there are two big heatsinks.
Free if you can pick it up from Wyckoff, NJ. This is amp only. No cables, speakers, etc.
